View Poll Results: what would be the next advisable upgrade?
Voters: 10. You may not vote on this poll
next upgrade
#21
sorry, forgot to answer this part of your question. i am trying to stay smog legal. so if tp does not fail me on smog, then i might consider it. if the greddy has no drone with cat, then i might just have that first.
#22
#23
Yes, there was very noticeable difference when Mac first installed them. I had to get used to the braking time and distance by lightly stepping on the brake pedal. It felt awkward and instant when braking at first but I've adapted. The OEM brakes are already very good but this makes it even better!
#26
There's not much need to upgrade the rear. What would be nice is if someone made two piece rotors for the rear to keep all that heat away from the hub, but we don't really need to get any more braking performance from the rear.
#27
![](https://www.s2ki.com/forums/images/s2ki/ranks/gold_member.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
[/quote]
TP is not smog legal, you wont pass with it on. You can always use your stock cat to pass, then swap it out.
All exhaust will have some drone. You can learn to drive around it for the most part.
#29
Originally Posted by madmaxblaster' timestamp='1346288222' post='21974780
[quote name='tkeyyy' timestamp='1346283699' post='21974626']
[quote name='madmaxblaster' timestamp='1346283152' post='21974601']
does the greddy exhaust have any drone?
[/quote]
[/quote]
Not true. Fuji leg R and Mugen has zero drone.
#30
Originally Posted by eklipz98' timestamp='1346290241' post='21974856
[quote name='madmaxblaster' timestamp='1346288222' post='21974780']
[/quote]
[/quote]
[/quote]
to add HKS dual with a 63mm TP has 0 drone. great sounding... some say no gains but saves weight. I have a greddy 70mm TI-C paired with a Berks HFC 70mm. If i'm cruising around 3500rpm+ then theres drone but not as bad as invidia. My friend runs it with a TP 70mm and he has very minimal drone. I like the sound better... louder then the hks but not obnoxious.
