California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Need to temporarily borrow AP1 ECU to test a CEL
Old 05-11-2011, 03:41 PM
  #21
dagle's Avatar
The immobilizer ring needs to read both keys theoretically if what you're proposing to work. Take the immobilizer key-ring reader off the ignition cylinder, and turn on the ignition with both key's heads within the ring of the immobilizer and try that. I
don't reprogram my ECU though!
Old 05-16-2011, 11:08 AM
  #22
kjalleda's Avatar
The ECU swap did not fix the issue .
>>I must basically tape the immobilizer key from the donor ECU to a non-immobilizer key that fits my car, so I need a new cut un-programmed key.
That worked, infact it is also in the s2000 manual.
I just got a new plain cut key from walmart ( without any transponder stuff ), cost me $2, and taped it to the donor key and started the car with the donor ECU and the car started fine. In-fact before I swapped my ECU, I tested the theory with my ECU by taping the new cut key I got made from walmart with my original key and verified that the car started. ECU swap is so easy if the donor ECU comes with a key programmed for it.
Next steps are to try replacing that white check valve, vacuum tank, air pump, and the air pump relay to see if it fixes things.
Crab Rangoon
03-04-2019 09:52 AM
Onizukasensei
08-28-2016 07:21 PM
mcopley
01-13-2012 09:01 PM
THE_DIESEL
03-02-2009 09:51 AM
Quick Reply: Need to temporarily borrow AP1 ECU to test a CEL
