California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
My top is not going down
Old 03-14-2006, 03:14 PM
martus2k's Avatar
Default My top is not going down
I checked the fuse and it looks fine but I can't make it to work. Any place where I could be able to check it out?? or any ideas..
ThANKS My S2000
Old 03-14-2006, 03:17 PM
jasonw's Avatar
Does the e-brake light come on when you have it engaged?
Old 03-14-2006, 03:18 PM
CrazyPhuD's Avatar
Alcohol? I've always found that to be very effective in getting tops down.
Old 03-14-2006, 03:19 PM
CrazyPhuD's Avatar
Seriously post in under the hood you'll get better response.
First check e-brake
then fuses
then motors
if you're not sure what you are doing get a tech to look at it.
Old 03-14-2006, 03:27 PM
martus2k's Avatar
I tried with the hand brake and nothing happens , then I tried the fuses and I found two on the right side of the engine and they look fine. How do I know that the engine for the top is out. Where exactly is it ? any idea.
Old 03-14-2006, 03:31 PM
Terrance914's Avatar
do the trouble shooting process of elimination:
1. when you press the button, does the motors make noise?
2. Is the top latch un latched?
3. does it move at all?
4. is the car on?
5. ebrake up?
6. ebrake light on or off?
7. can you open manually?
Old 03-14-2006, 04:00 PM
AsianQing's Avatar
Even though the fuse look okay, you might want to replace it and see if that helps or not. If your car is still insured, then you should be ok. Can you hear motor when trying to fold it down? Does it move at all? Could be your e-brake.
Old 03-14-2006, 04:28 PM
martus2k's Avatar
The motor doesn't make any noise, I am not sure about the ebrake light on. Mostly likely is not on but the hand brake is pull up all the way. I am going to check it after work. I can't pull the top manually is kind of hard or stock. But when I press the boton with the car on and top release still doesn't make any noise.
Old 03-14-2006, 04:31 PM
Eluded's Avatar
take her out to a nice dinner, throw in a i love you and the top is bound to come down
Old 03-14-2006, 05:25 PM
Banned
kayvan_pour's Avatar
Quick Reply: My top is not going down
