miss shift nightmare
MY00
AP1
90,XXX MILES
ok so ill make this short and to the punch , i miss shifted on the frwy about 65-70 mph i went to 2nd instead of 4th. being that i have the j's clutch and flywheel set up in my car it all happened really fast and hard i pulled it out of gear as soon as i could react. i drove for maybe a half mile then pulled over it was idling ruff and sounded like a wrx or something. its throwing misfire codes for 2,3,4. my question is whats the most likely damage done? valve clearances bent valve cracked retainers. and if there is anyone willing to take a look at it i would be very greatfull!
AP1
90,XXX MILES
You most likely cracked your intake retainers. Don't continue to drive the car! If your not comfortable inspecting the retainers have someone do it for you. Most likely all you will need (should) do is swap out the intake retainers for the AP2 version and you will be good to go.
i did the same thing 3 years ago, go thru my thread and here are the pics that u most likely will see in your engine
(your clutch and flywheel should be fine)
dont fix this engine, get a new one its 2300 brand new from dealer (short block) and get a good condition used head
I have seen many S2000's over rev and not bend a valve, just crack retainers. You need to pull the valve cover and inspect to really determine whats going on.
Originally Posted by dagle' timestamp='1306869188' post='20634656
At the very least you bent a valve. At the very worst you have cylinder wall damage.
In both cases, the head's coming off.
Sorry to hear about your car. I had cracked retainers replaced earlier this year. Here's my thread which also has some links to other threads that might be helpful (info, DIY inspections, Kaan's thread, etc):
https://www.s2ki.com/s2000/topic/847...alve-retainers
Hopefully the damage isn't too major since you were only going 65-70 when it happened.
