Looking for a set of stock injectors I can borrow
EDIT.
Looking for a set of stock injectors that I can borrow for a weekend.
Ran a bottle of redline through and killed the tank of gas + filled up with new gas, did ecu reset/idle relearn. No difference. Going to pull the injectors to see if the redline did any cleaning at all but would like to swap in some clean injectors at the same time.
I recently started datalogging my 2005 using the torque app and noticed my long term fuel trims and short term fuel trims were pretty high in the negatives. They been showing up as -11 to -16. However, this only happens when there is no load on the engine (clutch in or idle in neutral). Most of my searches say it shouldn't be in the double digits but I did find one post on here that says it is normal. Anyone have logs they can share?
If not, anyone willing to let me log their car around the block during a friday milpitas meet?
On a side note, I tried logging with a wifi dongle and the iPhone app as well and found that it could log a Fuel bank #3. I am not sure exactly what it is logging because I don't think there's a fuel bank #3. Numbers from those logs look normal though.
I have a post in UTH with a better description of what happened and what I have tested so far.
https://www.s2ki.com/s2000/topic/110...ve-fuel-trims/
riceball777
06-16-2015 10:37 AM
