i bought some gauges
i just got some gauges a couple days ago i just needed to know if i needed anything else beside the gauges to install. i got water/oil temp and oil pressure. thanks
sandwich plate that goes between oil filter and oil cooler for the oil temp and press. also at the fuse box inside the car on the left there will be 3 open pins one is hot 24/7 one will be hot with the light switch and one will be hot with the key in run position, you can use those for the power but make sure you run a fuse first. hope this help
