help/advise needed
help/advise needed
whenever i turn the wheel all the way left or right to make a U turn, i hear some weird noise coming from the rear area....any ideas of what it could be or if it's normal? i don't remember it doing this before, but i could be wrong?
Originally Posted by s2kheat,Jul 8 2006, 06:40 PM
What's the noise sound like? Popping? metal to metal?
Is it a continious sound when going straight also? If so, could be your rear brake shoes that need replacing. When's the last time the brakes were checked or changed? Here's a helpful clue. Look under the hood and see where the brake fluid level is. If it's low then you need a brake job. Don't replace the fluids as this is a sure indication. When the brake job is completed, and you retract the calipers, the brake fluid will go back into the plastic filler.
If your hearing it only when turning, you might want to have your bearings checked.
