FS: 00-03 OEM wheels and tires $425
<<< NEW PRICE >>> $425
Good condition stockers with practically new Sumitomo HTRZ tires(treadwear rating of 160/some track folks use it as well). Correct rear tire size in 245's for nonOEM spec. 100% tread remaining in front and 95% remaining in the rear. I was busy the past few months and never really put miles on the car since buying these tires. $425 takes it. I can deliver if you live in or near San Jose.
Tirerack quote: "The Sumitomo HTR Z is an Ultra High Performance "summer" tire that features an offset "V" directional block tread design that extends laterally towards the shoulders, efficiently removing water from the contact patch to enhance wet traction and resist hydroplaning. A continuous center rib maintains rubber-to-road contact to provide straight-line tracking and stability when cruising at highway speeds. Internally the HTR Z has twin steel belts that are reinforced by jointless nylon plies to provide high speed durability and tire uniformity. The HTR Z's sidewall is reinforced with steel inserts for faster steering response.
On the road, the Sumitomo HTR Z was also praised for its good ride comfort and low noise level while it also provided real world handling appropriate for its category."
