Fixed Gear Bikes
Fixed Gear Bikes
If anybody is into fixed gear bicycles ... I had a couple questions.
I'm looking to get a Mercier Kilo TT track bike and I noticed the sizing on bikesdirect.com is a bit different. When I rode my friend's Fuji 56mm It was a bit big so I wanna get a size around 54-55. Mercier doesn't have 54 or 55 and they have this whole sizing crap I don't get. Can someone clarify this for me and recommend a size?
Here's the sizing they have:
NOTE: Sized center to center, most riders fit a size smaller than they fit in a center to top sized bike
Example - if you ride a 58cm center to top sized bike then you may prefer the 55cm Kilo TT
Please refer to the sizing charts before making your own purchase decision
Sizing: (c-c = center to center seat tube, c-t = center to top, TT = top tube c-c)
47cm (c-c) is 50cm(c-t) with TT of 513mm and standover of 29 inches
50cm (c-c) is 53cm(c-t) with TT of 523mm and standover of 30.4 inches
53cm (c-c) is 56cm(c-t) with TT of 548mm and standover of 31.5 inches
55cm (c-c) is 58cm(c-t) with TT of 565mm and standover of 32 inches
57cm (c-c) is 60cm(c-t) with TT of 575mm and standover of 33 inches
60cm (c-c) is 63cm(c-t) with TT of 606mm and standover of 34 inches
63cm (c-c) is 66cm(c-t) with TT of 630mm and standover of 35.5 inches
Originally Posted by an_orange_s2k,Apr 30 2009, 11:56 PM
fixed gear = the new bandwagon
i spent enough for my fixie a long time ago. i could have bought a 240!!! HAHA
no really. i could have.
Originally Posted by itS2Krazy,Apr 30 2009, 10:21 PM
i got confused when i was buying mine. im 6 feet tall and i ride a bianchi pista thats a 55.
I went through the same thing when i was looking for bikes.. I know on a road bike, i need 53mm TT.. c-c, with @100mm stem. On a mtb i'm about 22.5" to 23" Depending how i want the bike to handle and style (xc hardtail or all mountain FS). I found this out subjectively trying different size frames with many different stems. Hurting myself in the process. But i got pretty close.. I finally went to get an ergonomic bike fitting. Here's a link to some info. Most pro-athletes get this done (base line)and they 'tweek' their bikes for the event they are about to do.. Time Trail, Criterium, Hill Climb, Triathlon, Endurance/distance, etc..
Usually a short top tube will reduce the 'cockpit' length and make the bike feel quicker. Too short and you'll feel like your going to endo when you brake or wheelie when you accelerate. As an extreme example would be a gorilla on a tiny bike. (top heavy) Vise versa, if the top tube is longer it will provide a more stable ride but steering will 'feel' slow. Too long and you'll start to 'feel' stretched out. An extreme example would bike a little kid on an adult bike.
Ideally, the 'cockpit' should be sized to support and spread the load your torso. In general your torso should be a balanced triangle. The points drawn from the seat to the handle bars to your head. This will get tweeked depending on the riding you do. (this is what i was told when i got ergo fitted)
So the Top Tube length is way more important to me than the seat tube height. The seat tube height is more important to me on, say a mountain bike, where i need to get off and on more often. And if i need to 'bail' off the bike, i don't have to worry about finishing the ride as a gal. This is a big peeve of mine when looking for bikes, mtb's usually measure from the seat tube in inches and road bikes are measured metric. Some bike have radically sloping top tubes and they use a virtual TT length! I think they need to standardize the measurements.
For me, I found out I have a long torso, with short(er) arms and legs. (azn build) So finding a bike that has a low stand over height and longish top tube was hard. Most road bikes have 52cm or 54cm. So finding a 53cm TT frame was hard. The stem was non-stock too. the 52~54cm bike usually have 100mm or 110m length stem. I had to find a 105mm length. Then crank length, I'm between 175 and 172.5mm, i opted for the 172.5mm because i wanted spin more on the road bike. On the mtb i have 175mm crank length for more torque/off the seat 'cranking'. (kinda a motor with different rod lengths)
It would be kinda hard to say what size frame would fit you best w/o seeing you on a bike spinning. But I'll try to answer your question, from what you have given. The Fuji bike sized 56mm, has a Top Tube of 560mm. (which was a tad big) A 54cm Fuji has TT of 550.8mm. The Mercier's 53cm, has a TT of 548mm. I think this would be a good starting point. Then you can play with stem length to dial in the fit.
I hope this help out and not too overwhelming. But once you ride on a properly fitted bike.. It feels like a tailored suit. You'll be able to ride longer, go faster and harder without the 'bad' soreness. (back, knees, shoulders, neck) Heh, sound like a Viagra ad!
