California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Door side speaker
Old 12-24-2012 | 09:14 AM
TougeHorseman's Avatar
Originally Posted by Ghregy
Originally Posted by XenonKiller99' timestamp='1356331839' post='22227348
[quote name='eklipz98' timestamp='1356331696' post='22227346']
Anything Focal, don't waste time with OEM.
Focal are pricey! I'm no baller like Casey! lol
Casey's a Baller!!! lol
[/quote]
I believe it's worth it to spend the money on focal. I get the mid range ones not the baller ones. If you ever want a demo let me know and bring ear plugs.
Old 12-24-2012 | 09:15 AM
I have the same deck as Casey..
Hell yeah. My philosophy is not to splurge on a deck in a car like the S. the alpine decks are bulletproof and have all the inputs and EQ control I would ever need. Something more complicated would likely not get used.
Old 12-24-2012 | 10:01 AM
Kalibos's Avatar
Hello,
There is a wide variety of speakers out there in the market that are good. 100-200 dollar speakers will net you some very decent speakers. 300-350 is the next "stage" of speakers. You definitely want to get components. That's almost a must and no reason not to unless you have door panels without the tweeter hole and don't feel like fabricating or buying new door panels.
Things to look for when buying aftermarket speakers are:
1. Speaker size and depth. If I remember right the stock speakers are mounted in a basket. They are 5 1/4 in size but you can upgrade to 6 1/2's. You can either buy a new mounting adapter or alter the existing basket to fit a new speaker. Depending on the speaker you can skip the basket/adapter and mount the speaker on to the door but then you can run into depth issues and/or vibration. Depth issues will not allow you to fully close the window since the magnet will get in the way. You can easily mitigate this buy simply either by making an adapter, using or modifying the existing basket or buying new universal speaker adapters (20 bucks online).
2. Tweeter mounts.The mounts on the door panel that hold the tweeter can be modified to support your new tweeters. It's just good to know that it's not plug and play and some tweeters are trickier than others to fit. Majority of all of them fit, just takes some finagling and maybe minor altering/fabricating.
3. crossover location. majority off all components (decent quality ones) come with a stand alone crossover. Not the inline solid state type on the wire. There is a nice place on the inside bottom corner of the door panel where you can locate this.
4. While your there, think about dynamiting. Helps a lot imho and adds little weight. Some will argue that its not worth it, it adds weight and costs money. Imo, you can find decent priced matting and the weight added is minimal...extremely minimal relatively speaking. It's worth the better sound quality. The only negative is that it's time consuming to properly install. I did inside (back of the outter shell) and outside (where all the holes are and where everything mounts to).
5. If you wanna go a step further, can replace the stock wiring from the speakers to the head unit or amp. I wouldnt do this until you install a stand alone amp if you choose to. The stock wiring is good enough if your not planning to get an amp.
With all that said, I have to refer to a comment up above. You can get the best speaker in the market but without a decent head unit, it means nothing. Post above is correct when advised to start with the head unit. The head unit is the single best upgrade you can do. Over the years the prices on head units significantly went down. You can get a really great head unit for a couple hundred dollars. If you need some help installing let me know.
v/r
James
Old 12-24-2012 | 11:08 AM
Ghregy's Avatar
Originally Posted by Kalibos
Hello,
v/r
James
Thx for the info.. I already got the after market deck, 2 amps and a sub.. Just need to change the door speakers.. Do I have to get a new tweeters?
Old 12-24-2012 | 11:57 AM
XenonKiller99's Avatar
^ Great post, James! "...start with head unit." *thumbs up* night and day difference!
I'd upgrade to components which comes w/ better tweeters, if u want enhanced and well defined highs!
Old 12-24-2012 | 02:56 PM
Kalibos's Avatar
I concur, you definitely want to upgrade to 6 1/2" components. They come with the Speaker, Crossover and the tweeter. Some also come with various size adapters and mounts for different applications. Using the stock tweeters with aftermarket speakers just complicates things. The extra couple of dollars for components are worth the sound quality and "user friendly" installation.
You mentioned you had two amps and a sub. I'm assuming one amp for the highs and one for the sub. Seems like you want a full system in your S. If that's the case your not really worried about weight and you want good sound. I want to encourage you to sound dampen some areas of the car and run aftermarket speaker wire from the amp to the components. "A chain is only as strong as it's weakest link". Stock wire will cause resistance and take away power (adds signal loss) and distortion. Make sure you run your speaker wire on one side of the car (drivers side) and the power wire on the other side (passenger) to prevent EMI and that "whine" you hear when you hit the gas. Also make sure your ground is as short as possible. Don't forget a cap and a good battery... Sorry for the run on info.. I'm not sure what your experience is with car audio.
v/r
James
Old 12-24-2012 | 03:45 PM
Ghregy's Avatar
^i have no experience on car audio. When I got the S it already have 1 amp on it. I don't know what the last owner did on the S. I just add another amp for the sub. Thx for the info..
Old 12-24-2012 | 04:21 PM
Kalibos's Avatar
Anytime and that's ok about the experience. That's the beauty about this site. Lots of good and kind people willing to share info and their experiences. If you don't know much about car audio I recommend going to a shop or a friend. It's not overly complicated or anything but there are a lot of small details that mean a lot in terms of sound quality and efficiently regardless of how good your equipment is. Don't forget that the S wasn't made with sound quality in mind. It's by far substandard when it comes to that compared to other cars in that category or under. So you have to make up for a lot of what was lacking to begin with. There is a lot of info on the web and in books that can get you thru if your a DIY type of guy. I do a lot of home theater and car audio and I can't tell you how many times I come across systems that just need a little tweaking and provide day and night results. Hit me up if you need help.. Good Luck!!
v/r
James
Old 12-24-2012 | 05:11 PM
maikoh's Avatar
I have a set of Morel Tempo 6 components with about 2 layers of dynamat in the door panels and I must say, it was well worth the upgrade for the super clear mids and highs. However, don't expect to get much bass out of component speakers. The mid range bass is definitely better than OEM speakers but if you've been in a car with a sub set up (even an OEM sub set up) you will not be happy with the lows unless you fork up a good chunk of money for a sub.
Old 12-24-2012 | 05:24 PM
I have a basic alpine deck but my focal speakers are powered by a Precision Power amplifier (the old school quality one) running 5 1/4 inch Focal components. The tweeter, speaker, and crossover box fit fine with minor tweaks and plates. Ample dynamat is applied to interior portions of doors as well as throughout the trunk lid and trunk bottom. My impression was that a basic deck is ok as long as you aren't using it to power the speakers. If you want real sound let the amplifier and amp tuning knobs control the majority of the EQ type settings and use the deck for some very base functions like source control, volume, and subwoofer level.
My setup is more SQ focused than SPL focused. I just used a four channel amp with two channels for the speakers and two bridged into a 12" 12-year old infinity kappa perfect sub.
Also not yet mentioned is this thread is the need for a DCI. I used a PAC and it works perfect. I would probably get the modifry if I could do it all over again I would do modifry DCI because he is the man. There's no sense getting a special stereo and losing half the buttons on the dash. My "mute" button doesn't seem to work with the PAC DCI for whatever reason.
