DIY: Differential Mount Collars
Hi guys.
This is a DIY for differential mount collars especially for those budget track junkies.
Thought it would be nice to share with the rest of you.
(Do at your own risk, I take no responsibility)
What: This helps with less movement of the differential due to age and wear on the mounts.
Why: Found one differential mount was starting to tear
How: Was talking to Edwin the other day and he brought up this clever idea of covering the mount with Polyurethane. What this does is it acts as a stiffer mount due to the polyurethane aiding with the mount making it stronger but without the high end cost. According to Edwin, this is an old-school trick within the budget.
Let's get to it. (takes under 30 minutes)
What you need:
-A tube of: Loctitie Polyurethane Construction Adhensive (PL Premium Advanced, 60A) or (3M Window Weld, 65A) = $7
-A caulk gun
-A knife or a scraper (to smooth the surface)
-The 4 differential mounts
1) Wash your mounts free of dirt and oil/grease.
2) Cut tip and break seal on tube, insert into caulk gun.
3) Apply polyurethane in all holes of the mounts
4) Make it look pretty
Give it a day to dry but if it was me, I would let me sit for a week before installing them.
Have fun!
Will report back soon with results.
What you need:
-A caulk gun
Have fun!
S2KRS13 (02-27-2022)
I could see the potential for this in conjunction with the collars to give the compound supporting surface area for resistance & flex; however my concern would be what would happen once the OEM mount ruptures - where/what would happen to the fluid?
Maybe I wasn't clear in my DIY.
jean-roch
01-11-2014 02:15 PM
Paul_J
04-26-2009 07:58 AM
