California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
check engine light came on
Old 03-09-2007, 02:38 PM
problem_child's Avatar
Originally Posted by yellowap1,Mar 9 2007, 03:01 PM
I would stop driving your car. Have someone come and check it out... do you have mods? or tow it 2 a dealer.
Old 03-09-2007, 02:46 PM
spree's Avatar
majority of the CEL coming on is for the loose gas cap... code 1456 i think... so hopefully it's something minor like that... don't drive the car around too much w/o checking the code first... in case it is something more serious.
Old 03-09-2007, 02:51 PM
Suspension's Avatar
Is it the check engine light or the maintenance light? These are two different lights. The maintenance light can be reset by you, there is a procedure in the manual. If it's the check engine light, then use the advice above. But if the car runs fine, don't worry too much, just get the code read.
Old 03-09-2007, 02:54 PM
an_orange_s2k's Avatar
its the check engine light. sucks im stuck at work i wanna take care of it right now
Old 03-09-2007, 02:56 PM
dont take it to the dealship. They will rape you. AND PLEASE DONT TOW IT
Old 03-09-2007, 02:59 PM
s2kennmark's Avatar
with CEL, i would drive it around (if it runs fine) so the ECU can adapt again and it will clear it by itself.
it might just be some minor stuff like if you just filled up from a different gas station, some tiny particles got in the MAP sensor, O2 sensor caught something, etc. etc. like i said the CEL is about emissions so drive it around and within 5 cycles it should go away.
if you want to check it, check the MAP sensor, gas cap for minor stuff... then you can go deeper to spark plugs, coil packs, etc... anything that will affect your a/f ratio can throw a code.
Old 03-09-2007, 03:16 PM
What The's Avatar
Ken,
You do not need to tow it anywhere unless it's a blinking CEL.
Autozone doens't read them for you anymore, but they rent them for free. Get the reader and pop it in at their parking lot to find out the code. It could be anything. Don't clear it unless you find out the code first.
You don't need to take it to the dealer to clear it, you can pull the fuse.
Old 03-09-2007, 03:33 PM
yea i didnt think it was really a big deal. im just planning to fill up since im low on gas and drive around for a bit tonight. if anythin i'll take it into kragen 2m morning
Old 03-09-2007, 04:57 PM
macr88's Avatar
If it's seems to run normally then don't worry. I'll check it for you Saturday or Sunday.
Saturday HIN
Sunday Auto X
Old 03-10-2007, 07:29 AM
SOHCmyDOHC's Avatar
Originally Posted by s2kennmark,Mar 9 2007, 03:04 PM
you can check the code yourself using the "paper clip" method.
CEL is nothing to worry about, that' all emissions... you can just wait after around 5-10 start restart cycle, it should go away.
You can still you the paperclip method?? Didn't know that...
Quick Reply: check engine light came on
