California - Bay Area S2000 Owners California Bay Area S2000 Owners Group
Autozone torque wrench
Old 11-28-2014, 08:44 PM
taifei's Avatar
Default Autozone torque wrench
Anyone rent one of these from autozone before or know how accurate they are? The one I'm using only goes up to 150. I need one for 181 ft/lb but rather not buy one and only use it once.
Old 11-28-2014, 09:14 PM
S_DosMil's Avatar
I used to work there. As far as accurate not sure. We don't calibrate them. And yeah only up to 150 we didn't have any that went higher. Unless you buy one we can special order it from a tool catalog.
Old 11-28-2014, 10:23 PM
dagle's Avatar
181ft/lb is that the crankshaft pulley or the axle nut?
edit: nevermind just read that you have a 150ft/lb calibration. Just max out your current torque wrench and give it an extra 1/4th turn with a breaker bar. It'll be a tad over 200ft/lb but safely over 180.
Old 11-28-2014, 11:06 PM
S_DosMil's Avatar
This is what I did lol
Old 11-28-2014, 11:32 PM
taifei's Avatar
thanks. ill give it a shot
Old 11-30-2014, 02:10 PM
dagle's Avatar
What is it you're working on that requires 181ft/lb?
If it's the axle nut, you want to go substantially higher than the recommended torque setting as prescribed by the TSB. I personally went over 250ft/lb (probably 300+)
Old 11-30-2014, 08:51 PM
taifei's Avatar
crank pulley. replacing with a comptech one
Old 12-01-2014, 05:54 PM
dagle's Avatar
Old 12-01-2014, 06:41 PM
Banned
jr94513's Avatar
Where are you located? I can loan you mine
Old 12-01-2014, 07:19 PM
taifei's Avatar
Fremont/UC area. Won't need it for a week or 2, need to help clean up my cousins garage so we can work on it inside while it rains.
Autozone lists a 30-250ft/lb 1/2in drive on their website under rent a tool but I guess not all stores carry them.
Quick Reply: Autozone torque wrench
