aligning the front lights
my right side light is way out of alignment, is there a shop or place you guys recommend where I can have to aligned and fitted in right?? the right side (passenger side) 's HID is way off, ahhh need help.
The right side of the headlight cutoff mask angles up a little bit normally, so your car may not be misaligned as much as you might otherwise think. In any case, the lights are easy to realign. Open the hood and look for the hole in the side panel of the engine compartment behind the right hand headlight. Inside the hole you will see the vertical alignment knob. You can use either a metric socket or a phillips head screwdriver to make an adustment. Insert the screwdriver between the two plastic fingers, engage the teeth on the edge of the knob and twist. To adjust the left hand headlight you will have to remove the coolant overflow tank to access the hole.
