7k bogging
7k bogging
So on the way home tonight in 2nd gear the car feels like it hits the rev limiter at around 7k then after a second or so goes to 9k. In 1st and 3rd it does not do this. I did some searching around and yes the car is warm and it doesn't have forced induction(a lot of the searches yielded these results) I'm puzzled as to why only one gear? Plugs have maybe 6k miles and oil change is recent. Compression test about a month ago was good 215,210,215,215. Any help would be appreciated
I'm thinking ecu or speed sensor issue?
Yes 3 bars and probably even 10 minutes after 3 bars before I got above 6j
It was in the name if testing. Road was empty two lanes in each direction so I was trying to be safe haha
Originally Posted by TougeHorseman' timestamp='1405104914' post='23239897
I can't help solve your problem but I do like hearing that you're hitting the limiter in third gear on your way home! Now thats my kind of commute!
Originally Posted by S_DosMil' timestamp='1405107683' post='23239972
[quote name='TougeHorseman' timestamp='1405104914' post='23239897']
worries.
[/quote]
I do go to the track but once in awhile gotta clear the pipes!
Outta town this weekend won't be able to check anything till Monday. Oil is good btw
Well I'm back in town and drove it around the problem is through all gears and intermittent. I can't peg it down. Just seems like I am not getting the fuel injectors and creating the bog. No check engine codes
cruising_in_my_s2k
10-04-2010 11:37 AM
