64mm to 73mm hubcentric rings x2
![](http://i101.photobucket.com/albums/m69/arielrylis/20120822_142512.jpg)
Anyone have two extra hub rings sized 64mm to 73mm for the rear wheels?
I got new wheels but they sent me 70mm to 73mm x4 hub rings by mistake
thanks for the help!
![](http://i101.photobucket.com/albums/m69/arielrylis/bluethumb.gif)
Agreed you don't really need them. Just make sure you tighten the lugs in the star formation with the wheel up in the air so it aligns itself. Never had balancing/vibration problems without them. And I have the rings and I still don't use them. Also make sure you have to correct lugs for aftermarket wheels. The tapered ones.
Originally Posted by Voodoo_S2K' timestamp='1345671886' post='21957076
You don't really need them.
I used them a couple of times, but they always fell out while I was trying to put the wheels on, so I eventually stopped bothering with them. Plus, I used the wrong size once on the front and almost met with disaster!
Mine are 76 to 64.1, though, so that won't help you.
