Automotive builds Got an automotive build you want to want to document? Post it here!
S2000 street driven TT car build
Old 11-28-2017 | 10:58 AM
  #81
Sickdayracing's Avatar
Some winter maintenance. Completed the valve adjustment. Also installed chicken wire in the grill. I have a transponder, Mishimoto radiator, and oil cooler up there. Alot of expensive stuff to protect up there!
Old 11-28-2017 | 04:47 PM
  #82
I got some of the stickers we are required to run custom done in black and die cut in black. I also took the day to really clean the car, polish it, and wax it for next season. Tons of little things to do here and there while the suspension is away.
Old 12-04-2017 | 06:17 PM
  #83
Installed my diff collars. This turned into a real pain in the ass because one of the welded in bolts for the diff mount broke off. I was lucky enough to fish a bolt through and nut it on the other side. The fixed worked great and is probably better then how Honda did it. I also went and checked the torque on all my subframe bolts and alot of them were loose. This should be on everyones winter to do list!
Old 12-04-2017 | 06:19 PM
  #84
On the side note, I went to get my NSX aligned toadied and I did the first oil change after the break in miles. She runs great!
Old 12-04-2017 | 06:38 PM
  #85
Midnightdennis's Avatar
Nice progress!
Looking to get a hardtop for my S. Can’t tell from pics if yours is authentic mugen but it looks great. If not, which brand did you buy? Any insight on fitment, seal install, cost to paint? Much appreciated!
Old 12-04-2017 | 07:18 PM
  #86
Grip Hrd's Avatar
That NSX is gorgeous, what year is that?
Old 12-05-2017 | 03:55 AM
  #87
1992.
Old 12-05-2017 | 03:57 AM
  #88
Originally Posted by Midnightdennis
Nice progress!
I have a VIS Mugen but going to a OEM style next year for TT5. The seal and fitment on my VIS is significantly better then the Forbidden Mugen from my experience. The Forbidden tops I had popped and cracked and felt flimsy. The VIS is significantly thicker but the rear window wasn't as big. Take my experience with a grain of salt though because from what I have read there is a significant difference in VIS tops from top to top.
Old 12-05-2017 | 04:22 AM
  #89
Originally Posted by Sickdayracing
I have a VIS Mugen but going to a OEM style next year for TT5. The seal and fitment on my VIS is significantly better then the Mugen from my experience. The Forbidden tops I had popped and cracked and felt flimsy. The VIS is significantly thicker but the rear winter wasn't as big. Take my experience with a grain of salt though because from what I have read there is a significant difference in VIS tops from top to top.
Thanks for the reply. I’m in the market for a red/black mugen hardtop. Let me know when you’re ready to part with yours! I’m in the DMV area so pickup would be a breeze.
I’ve heard the same inconsistency issues with VIS tops; glad to see function and form isn’t lost here.
Old 12-13-2017 | 05:11 PM
  #90
Some updates. I had neoprene brake ducts that I bought last year. They didn't even last a season before developing holes from rocks and tearing apart. I spend the extra money this time and went with silicone ducts.
TT5 stickers are here so it is official that is what I am running in now. I got all die cut logos so they match the car and put them low as possible so they aren't distracting. I sold my AIM solo in anticipation of the new AIM SOLO 2 coming out.
Also, my hardtop is is a .4 hit for TT5 so I traded someone for a Forbidden double carbon OEM top. I had a Forbidden top before and it is just as shitty as I remember it to be. I plan on refinishing it as well as putting some spray in insulation in it to make it less shitty. Also, my custom roller was made to work with a Mugen top so I will need to notch the OEM top to work with my existing setup. I'm pretty nervous about but lets see how it goes. More pics to come!
Quick Reply: S2000 street driven TT car build
