Automotive builds Got an automotive build you want to want to document? Post it here!
S2000 street driven TT car build
Old 03-06-2018 | 03:11 PM
  #121
freq's Avatar
Originally Posted by Sickdayracing
You can but you take a -.5 hit.
I'll be running with NASA NE May 4/5/6, June 8/9/10, Sept 28/29/30.
FTFY. See you there.
Old 03-06-2018 | 03:54 PM
  #122
circuitclub's Avatar
awesome build, what tow straps are you using? - I really like the design
Old 03-06-2018 | 03:55 PM
  #123
Sickdayracing's Avatar
NRG. I might be selling them. They keep destroying my shins when I walk by the car in my small garage!
Old 03-06-2018 | 03:57 PM
  #124
if they hold up to tows, hit me up; I could use a set. I like that they are easy to put on and take off. and that they are green
  #125
Here is my event schedule for the year. Hope to see you guys at a few!
Date Track
March 16 Summit
March 23-25 VIR
April 21-22 Summit
May 4 -5 – 6 Lightning
May 18-20 VIR (Hyperfest)
June 8 – 9 – 10 Thunderbolt
July 14-15 Summit (Finale)
July 19-22 : PCA Glen HPDE
August 10 Summit Seat Time
August 25-26 VIR
Sept 13-16 COTA NASA Nationals
Sept. 28– 29–30 Watkins Glen
October 6-7 VIR
Nov 10-11 Summit Point
Possible:
June 9-10 : Summit Point
June 15-17 : Global Time Attack NJMP
Old 03-06-2018 | 04:08 PM
  #126
freq's Avatar
Can't say I like rigid tow hooks. Not only shins but they can wreak havoc on bumper covers.
There's a lot to be said for full straps.
draft.
That's a lot of Sick Days. And always on a Friday?
Old 03-07-2018 | 07:45 PM
  #127
Got some sticker 225/40/17 R7s and 255/40/17 RC1s mounted on 17x10 6ULs. 6lbs weight difference per corner is huge!
Old 03-09-2018 | 04:19 PM
  #128
Got the car back from corner balance and alignment and everything seems great. I ended up using only 1 25lbs ballast brick. The car with a full tank of gas and RC1s weighted in at 3019lbs. Subtract 24lbs for R7 and 29lbs fuel burn it puts me right at an adjusted 14.0 p/w ratio for TT5. I typically burn about 15-18lbs per session and fill up every session so I have enough buffer to be legal incase the scales are slightly off. I will also bring an extra 10lbs incase the scales are way off.
I had the alignment and corner balance done at Ptuning.
Alot of guys are secretive about setups. I am not because I'm not really doing anything too special with the car and also because if I am doing something that works, I want other people to use it and have their cars optimally setup as possible and not waste time with failed setups.
Here are my alignment specs that I have used for the last 2 years or so;
Front:
Camber: 3.2-3.5 (whatever you can get max)
Toe: 0
Caster: 6
Rear:
Camber 3.2
Toe: .15 degree each side, .30 total
My corner weights were as follows:
LF: 778
RF: 731
LR: 777
RR: 732
Cross: 50.03
Note: These weights are with a full tank of gas and 200lbs driver.
I previously had 3.5 degrees camber up front but raised the right height slightly and wasn't able to get more then 3.2. A few people have asked me about balljoints vs offset bushings. I have used both. On my AP1 I had offset bushings and was able to get -3.9 and on my AP2 I was able to get -3.5 with balljoints. Of course these numbers don't mean much because ride height will have a big impact on numbers. Both balljoints and offset bushings do the job. The balljoints are probably easier to install though.
I've been going around and nut and bolt checking everything just to make sure everything is good. Alot of stuff came off and back onto the car so I want to be 100% sure everything is good before testing next Friday at Summit Point.
I installed a steering wheel hook as well. I have a couple of pictures of where I mounted my new AIM SOLO 2 as well as how I mounted my GoPro. The Hero 4 only has USB hook up and I like to use an external mic. You can only have power or an external mic hooked up, not both. My solution to this was an extended battery back pack so I can keep the back pack plugged in as well as the mic. Works great!
A few people asked about how my did my belts with the surgical tubing. Here are some updated pics.
Old 03-10-2018 | 03:11 PM
  #129
Chibo's Avatar
That tubing idea is genius.
Old 03-13-2018 | 11:02 AM
  #130
Would you mind sharing which roll bar mount you are using for your GoPro and roll bar dismeter?
thanks
Quick Reply: S2000 street driven TT car build
