Temperamental Battery
I know this has been talked about before but I just want to emphasis how temperamental the stock battery can be (or how quickly QuikTraK can drain it). My car is just 1.25 years old but doesn
It might be 1 volt under no load but it could be the difference between 7~8V and 0V when the starter's engaged. The amount of current the battery can supply drops dramatically as its open circuit voltage falls.
If you have a QuikTrak and don't drive the car a lot you'll save a lot of aggro if you get yourself an Odyssey battery. Normal lead acid batteries die in a hurry (and permanently) if they ever get heavily discharged. They are not designed for deep cycling.
which odyssey battery did you get naishou? Did you have to make any modification or did it fit straight in?
I need to get some dry battery. Last time I checked under the bonnet there were a lot of acid leak from the honda oem battery and I dont drive my car that hard
Er, I didn't. I have one in my racing car. Because they are smaller you'd need to arrange some slight modification to hold it in place but the terminals should be compatible.
