Spoon Filter Installation Help
Hi,
sorry if this has been talked about, but i can't understand the instructions given by Spoon for the installation of the Air Filter.
It says that i should remove the air duct on the box top, and to block off a little hole found below the air filter.
ALso to remove the middle section of the box, less restrictive i guess.
Also something about a strap needed to be installed as well..
I know that by modifying the box, it gives it an extra 120% air increase (stated in the instructions), but i need to know, what exactly needs to be done.
Can someone share some light to this issue Please...
Thanks
CHRIS
Thanks
CHRIS
Just so you know, the hole in the bottom of the air box and the divider between the two chambers are part of the S2000's hydrolock protection. The idea is that water that makes it's way into the air box gets trapped in the first chamber and drains through the hole.
There is a useful thread on this very subject ongoing in the UK forum at the moment:
Airbox modifications
HTH
Tif
HTH
Tif
VGSS2K
19
03-31-2007 07:42 PM
ff_mark
03-14-2006 04:04 AM
