Australia & New Zealand S2000 Owners Members from the land downunder.
Shell Petrol
Old 11-22-2001 | 08:17 PM
s2k2's Avatar
Default Shell Petrol
Shell Optimax would be the best right for the s2k?
tks
Old 11-22-2001 | 08:53 PM
swells65's Avatar
Any of the 98 RON fuels should be OK. If I can't find a Shell, I'll go for BP, Mobil or Caltex as long as they have 98 RON PULP.
Old 11-22-2001 | 08:56 PM
bmoyes's Avatar
Most definitely.
I've run mine on normal unleaded, it took it fine, but given the choice you should always use fuel with 98 octane or higher, as that's what it's designed to run on.
RACV did a test with a few cars and found that it was not more expensive to use optimax, because you do get improved economy (as shell claim!).
Old 11-22-2001 | 09:14 PM
2kturkey's Avatar
BP and Mobil are also 98 RON. I find BP gives better top end performance than Shell but Shell reduces the off idle stumble. All up, given the cost difference (BP is always 5c a litre cheaper) and better high end performance, I prefer BP
Old 11-22-2001 | 09:24 PM
naishou's Avatar
Something that people might like to note before they go into the finer points of the differences between brands is that in each capital city there is only 1 or at most 2 refineries. All brands come from the same batch! This information comes from a colleague who used to work in the industry. It's no coincidence that they all started to introduce 98 RON around the same time (though Shell was a bit earlier). This leaves room for the additive chemistry to be slightly different however.
Old 11-22-2001 | 09:30 PM
swells65's Avatar
Yup, I heard that the brands are from common stock. When Optimax came out, so did BP Advantage in Adelaide. A spooky coincidence until you find that BP were buying locally from Shell.
Old 11-23-2001 | 01:54 PM
Takashi KazuMori's Avatar
My car drinks 100 octane and nothing less.
Old 11-23-2001 | 09:39 PM
Iggy_Type_R's Avatar
Not only a postwhore, but also a tosser.
Old 11-23-2001 | 11:57 PM
AnDy_PaNdY's Avatar
Old 11-24-2001 | 06:10 PM
Bernie's Avatar
Quick Reply: Shell Petrol
