Rear Speakers
Rear Speakers
Hi All, i am going to chuck in a set of rear speakers lucid style but as per usual it Honda Australia don't stock the parts i need. I am after a wiring harness car side as pictured below to nab the rear speaker wires from. the only harness Honda has locally is a full harness costing $500.00+. does anyone know what size the lottle inserts for the harness are, or have a spare harness around. any thoughts would be much appreciated.
Thanks
Chris.
Thanks
Chris.
Audio shops often sell these harnesses and in my experience most of the Honda ones are the same. If you can buy one with rear speaker wires you could splice it in. IF not, see if you can get the pins or a hraness with some pins and transplant them.
How soon do you need a harness?
I'll check at work for availability and see if i can send one up to you..might take a few days tho..
The pins look similar to what Jaycar stock.. so you might wanna check them out before butchering...
Let me know what ya wanna do
Matt
Matt
When I put rear speakers in my '99, I didn't use an extra harness, or wires from another harness, or anything. I just used normal insulated wire with stripped ends. I fed them through the harness, hooked them around the connection, and plugged it back in. Amateurish? Sure. Effective? 100%.
