Key fob not working, car is immobilsed
HI,
Briefly: the car battery is about 2 months old. I drove it today for 45 mins or so, all good.
When I went to lock it, the fob wasn't working, so I assumed it was the fob battery (the fob and battery was about 7 years old!). I replaced the battery and went to start it again 15 mins later. The fob still did not work, but since the car was still unlocked, I just tried to start it. The car is completely dead, no dashboard activity.
I think the immobiliser is stuck in engaged mode.
Any ideas 1) how to disable the immobiliser and 2) how to reprogram the fob so it locks/unlocks my car again?
Thanks,
Scott
Thanks,
Scott
Does your car have an alarm system fitted? If not all the remote does is lock and unlock the doors, it doesn't engage or disengage the immobiliser. There's a chip in the key itself which the car reads when you insert it into the ignition which disengages the immobiliser. Can't help any more than that though..
And also, the battery in my remote is 11 and a half years old and its still all good
Hi,
The S2K is a 2005 model with original equipment. Ok, well, the fob wasn't working, I replaced the fob battery, it didn't fix the issue, and now the key doesn't disable the immobiliser and the car is completely dead. I'm sure it's not a flat battery since I drove it not 15 mins earlier.
Thanks,
Scott
Thanks,
Scott
Try turning on the ignition switch and pressing unlock 10 times in quick succession. You often have to do this on alarm systems that use rolling codes so it works out where in the rolling code sequence the keyfob is at.
nissanfanatic
02-27-2013 01:54 PM
surfer_crx
09-18-2008 11:53 AM
