Australia & New Zealand S2000 Owners Members from the land downunder.
Diff ratio help and Yellow Box Help!
Old 08-31-2013, 02:27 AM
Flippit's Avatar
Originally Posted by BigDRichy
Originally Posted by Flippit' timestamp='1377695838' post='22749007
Thanks guys, may buy one with plug and play harness!
On dyno today the Dyno was reading 100km whilst my cluster showed 112km.
Are stock usually that much out? If not is it possible I may have 4.44's? mmmmm
What did your figures read on the dyno?
144kw. Stock besides an Injen CAI.
https://www.facebook.com/photo.php?v=10201901088113686
Old 08-31-2013, 07:05 AM
BigDRichy's Avatar
That's pretty good. By the end of the year you'll be on 160atw
Old 09-01-2013, 03:23 AM
Flippit's Avatar
No. Although there are several factors that can influence the reading, it shouldn't be in error by that much. Based on the speeds you've mentioned, you probably have a 4.56/4.57 FD (i.e. 112/100 ~ 4.56/4.1).
Well I just purchased the Yellow box with the PnP harness so it should be on its way soon enough.
Now just to figure out what settings to adjust it too
Old 09-01-2013, 09:29 PM
chris_barry's Avatar
set it to 112 initially then use the plus/minus fine tuning from there with a GPS.
Old 09-08-2013, 11:30 PM
Flippit's Avatar
guys i just received the yellow box V5 with plug n play harness.
Just wondering is the connectors on the driver side or passenger side?? As the pictures online show the left side which in U.S is the driver side but being AUDM would our still be located on the left side or is it swapped over to the other side? Just to save my self the hassle of ripping shit apart when I don't need to
EDIT : found some pics on s2ki its on the left side so AUDM passenger side woop.
EDIT x 2 : Just reading Chris_barry's review it looks like it plugs into under my car on the gearbox where the sensor must enter the gearbox. Am I correct in assuming this?
Old 09-09-2013, 01:49 PM
Yes, Unclip the plug on the side of the gearbox and put the YB plug and play harness between the sensor/loom plug.
Sensor is on the left of the gearbox.
MajorHavoc
08-03-2016 05:45 PM
MB
05-07-2015 06:59 AM
s2k2go
08-19-2004 12:08 PM
terrys2000
03-27-2004 05:30 PM
1Fast99Si
08-18-2003 05:43 PM
Quick Reply: Diff ratio help and Yellow Box Help!
