Corner weight balancing
Has anyone done corner weight balancing after installing their coilovers or simply just a wheel alignment? Also would anyone be able to rent or borrow out some corner weight scales for a weekend located somewhere around Sydney. I thought if you were going to buy coilovers for the S2000 you might as well install them correctly and not ruin the 50:50 weight distribution Honda worked so hard for.
I'm with mezza on this one. Even spirited driving wont show the difference unless your about 100kg out per corner. Provided the chassis is a consistent high to the ground all the way around you should be close enough.
Yeah I'll just leave it alone if that's the case. I have the car sitting evenly on all fours
christy
33
09-07-2003 08:56 PM
