Australia & New Zealand S2000 Owners Members from the land downunder.
Air Filter
Old 09-16-2004, 07:18 AM
Guess's Avatar
Default Air Filter
Have anyone changed their air filter in their car for a aftermarket item and left it in the stock box. Do you need to get a brace of some sort to hold the filter?
Is it possible? Just that mine is getting dirty and would like to change it for say a k&n reusable one. thanks
Old 09-16-2004, 02:26 PM
slick's Avatar
I have just changed mine to a K & N filter - fits straight in, no mods required.
PM me if you want one - can fit it for you too.
Old 09-16-2004, 02:28 PM
MattG's Avatar
Do you have a part number for that Slick?
Old 09-16-2004, 02:32 PM
slick's Avatar
Will look it up and post later.
Old 09-16-2004, 02:43 PM
AusS2000's Avatar
It's K&N E-2435. And that's from memory.
I did a group buy on them in August 2001.
Old 09-16-2004, 10:00 PM
slick's Avatar
Yep, that is correct Aus - the code is E2435.
Price around $140.00 incl, and a hand with fitting if required.
Old 09-17-2004, 11:17 PM
#69's Avatar
Slick and Aus did you guys notice any difference with the K&N?
Old 09-17-2004, 11:20 PM
AusS2000's Avatar
Yes, my wallet was lighter. Apart from that the only difference is that you don't replace them, you clean them. Mind you, it'll take quite a few changes/cleans before you break even.
Old 09-17-2004, 11:21 PM
AusS2000's Avatar
That said, I replaced the Comptech foam/oil filter with a K&N just because it is less messy.
Old 09-18-2004, 12:38 AM
RedRover's Avatar
I assume that if you use the K&N filter you can no longer put the top back on the air box - as per the photo above. Is that right?
If that's the case, then the patented Slick cold air intake would not be nearly so effective. Is that right?
Quick Reply: Air Filter
