Click noise from the back
Hi everybody
worry about this noise it is coming from the rear wheel like a click only when i launch the car from a standstill, so did anyone of experience the same noise and what was the problem and how to solve it.......??
thanks
thanks
If it is only under acceleration from a stop. It is usually the axle nut shifting on the rear hub. Remove the axle nuts lube the mating surface with wheel bearing grease (use spearingly).
Retorque the nuts to 220ft-lbs. Then steak the nut. Check wheel nuts for proper torque >80ft-lbs. Then recheck to verify that the noise is gone.
-Cesar
-Cesar
andreslval
07-16-2012 03:02 PM
