What are your thoughts on this?
What do you think would happen to the driving feel after adding these mods to the S?
-3.90 Gears
-Lightweight Flywheel
Here are my thoughts:
3.90 gears: allow a higher top speed at each gear and consequently causing it to not pull as hard. Additionally you will shift later (at a higher speed)
Lightweight flywheel: engine revs faster, thus achieving the peak power faster and you will need to shift faster (time-wise as revs reach 9k quicker)
So what would you think the result would be? Would an S with these mods pull as hard as a stock S? I know for sure it will have a higher top speed but what do you think about acceleration?
I'd like an S that can cruise at highway speeds @ lower revs
-3.90 Gears
im goin with 4.44's, at 70 i think there is only like a 300 rpm diff.
http://www.gtmotoring.com/mm5/merchant.mvc...2000-DRIVETRAIN
Now, a S/C w/ 3.90 gears might be a better plan.
w/3.9's cruising in top gear, expect to downshift a bit if you need to get moving
Heres a good link for some flywheel info
http://www.uucmotorwerks.com/flywheel/how_...wheel_works.htm
Wouldn't that gearing drop you out of vtec every shift? I think it would be a bitch for daily driving but you would probably get better gas mileage . A long time ago when I first got my car and I was young and dumb, I tried a top speed run but couldn't get it to the e limited 155mph.
