Valve adjustment settings
So I thought I'd do a valve adjustment while the valve cover is off.
All my intake valves are steady at 0.008
The odd thing is all my exhaust valves seem to be at or below 0.008
Spec says 0.010
Should I mess with it or leave it alone?
Car has 40k miles.
Spec says 0.010
Car has 40k miles.
I thought they only get looser over time?
I'm reading this
http://www.s2000.org/articles/valve_adjustment/
and it says tighter is not a bad thing...maybe it's supposed to be tight on the exhaust side if all my valves are set that way?
I'm reading this
They tend to get tighter. The valve beats into the valve seat . Over time this pushes the valve higher up into the head reducing your clearance/ making it tighter. It's easy to do and will take a extra hour. Might as well get it done and not worry about it for another 30k miles
I've seen intakes get loose on a couple that I've done but never exhaust. I imagine it has to do with the heat on the exhaust side weakening the metal making the valve seat a little softer.
