P0135 cel after header install?, help!
Just installed a Comptech header and the Invidia exhaust and this cel popped up. I handled the o2 sensor real easy. I cleared it but it just popped back up. Any suggestions?
Thanks,
Roger
Thanks,
Roger
O2 heater malfuntion. Check the amperage at the O2 sensor heater wire. It should be about .8 amps. If you have an OBDII tool, then you can monitor it by just plugging it in. As long as the O2 sensor works, you are fine. The heater is just to get the car up to temperature quicker so the pcm can start adjusting the A/F ratio and not be in open loop.
It was a blown fuse. Replaced the fuse (didn't look bad)
and cleared the code and it seemed to have fixed the issue.
A big thanks to Boofster (Ivan) for the diagrams.
The man knows his stuff.
Roger
Roger
phaze826
07-31-2004 07:21 AM
