OEM Paint
http://www.automotivetouchup.com/spray_pai...e=10:57:44%20PM
I need to paint my lip. I see you see this place sells an adhesion promoter for it. is that used as the primer? it kind of sounds like it is or should I prime after that step as well?
aerospace on country club in mesa does it... the match isn't perfect even with the factory color code. they mix up a quart and then it is $4 a can for aerosal cans to add it to. you can do 2.5 cans.
Originally Posted by Mercuri,Aug 12 2008, 06:53 PM
Can you get OEM paint in a spray can? im taking the cheap way out on a project...
Originally Posted by 707S2K,Aug 13 2008, 09:11 AM
Your "best" bet is to remove your gas door and bring it to a paint shop so they can color match it not only using the paint code, but also by the "actual" color. You have to consider that the paint might have a slight fade to it from over the years. If you get an exact OEM color, even from Honda, it might not match up.
