Need New Cylinder Head -OR- Machinist
Here's the stink.
A couple of years ago, I decided that it would be a good idea to change spark plugs. I was tracking my S at every event I could find where I could go fast and improve lap times. Yeah, I was in to the whole scene of beginner racing.
Well, Here's the deal... see. I put in new spark plugs thinking that I was all that in top maintenance and performance. What I didn't do was TORQUE the forkers to 18 ft-lbs. I trusted my previous experience where one hand tightens then "seats" the plug with a 1/8th turn from a wrench. WRONG!
The number 2 cylinder's spark plug, after a year, managed to blow itself stripped and I was faced with a removal of the cylinder head and insert in the 2nd cylinder to fix that hole.
Well... tonight I find that that number 2 spark plug hole was apparently just heli-coiled and the spark plug just isn't seating right ever. There is a gap in the sealing ring because it appears that the top of the heli-coil is not flush. Imagine a coil cut off and you've got what I'm seeing at the spark plug.
My S engine has a rhythmic, sewing machine rumble that co-incides with the RPMs and I'm thinking that it is because the number 2 cylinder has just a bit more volume and less compression than the other three.
Here's what I'm after...
I need a suggestion for a supurb machine shop...AND I'd also like to find a reputable source for a new 2.2L cylinder head.
I really need the techies and machine-heads here for a forum.
My S is not a daily driver and can be put in moth-balls while the cylinder head issue is fixed.
Either I find a magician machinist, or find a new head.
Word?
Word?
DO NOT DRIVE YOUR CAR UNTILL YOU CAN FIX THIS PROBLEM!
SAME THING HAPPENED TO ME!
Click These Links:
The Story
The Results
good luck with everything
Click These Links:
The Story
The Results
those are horror stories that I don't believe apply.
I did a pressure check, (Thanks Mervin), and the number 2 is 10lbs lower than the rest. What we see is when the number 2 spark plug is taken out that there is about 1/4 of the seal ring that is not compressed - even after the plug was torqued to 18 ft-lbs. upon closer inspection, it is quite obvious that the seating rim is un-even. It appears that a heli-coil was inserted but not flushed.
I can take a long skinney rod and run it around the base of the spark tube and it is then even more painfully obvious that the seating area is not flush.
I am willing to take off the head to have it re-finished - or look for a new cylinder head. Hopefully the piston walls are not scratched from debris.
Fellow Sk2 drivers and enthusiasts... TORQUE EVERYTHING ... including the farggin' SPARK PLUGS! I screwed up and feel terrible about causing damage to my excellent machine!
But machines can be fixed.
There has got to be a machinist in the valley who is considered an "artist". I need to find that shop.
Originally Posted by Bryan720' date='Jan 26 2009, 02:45 AM
I have a 2.0L head that I was going to put on my back up block. I think 00-05 use the same head.
Part No. 374091 (If I'm not mistaken), list at Majestic is $1335.
And it is indeed different on the 2006+ models.
Good luck!
some days I love how simple and long lasting these cars are... other days i think "what a brittle pile of #$%^" how could they make most of the car so sound and then have an issue like this... lame!
... well, it is a well-engineered machine with tight tolerances. I'm a bit disappointed with myself for not torquing the spark plugs a while back. I would torque everything and assumed spark plug seating is spark plug seating. Now, I torque everything!
Thanks for all the info!
Originally Posted by dat boi' date='Jan 25 2009, 09:35 PM
Go to the Honda dealership if you want a new head.
Used heads or even you current head can be machined, most likely, and cut your repair down to a fraction of the cost.
Originally Posted by Kyushin' date='Jan 28 2009, 09:11 AM
Dude, never ever go to the stealership... youll pay way more than you actually need to. Anyways, why the hell would you use a dealer in the first place when you have an elite shop like Science of Speed out here.
