How bad is it to mix oil?
I know that we have some pretty smart people in the AZ community so I figured you guys might know a little about this. I usually run 10/40 synth in both the Subie and the S2k, however I still have a couple of quarts of 10/30 synth from another manufacturer left from a previous oil change. The Subie burns at least 2 qts per oil change (more if I'm driving vs the wifey driving) whereas the S2k burns maybe a half quart. How bad is it to mix brands and weights as I would like to use the other oil as "top off" oil?
I agree with Boofster, your not running your motor at the edge for extreme periods of time. I've mixed Valvoline and Royal Purple before, for some reason I didn't buy enough quarts of oil for the oil change and I had some RP left from before. I ran the mix for about 4,500 miles no problem. I think you should be fine. By mixing weights you'll just get a different viscosity.
As far as the Subie goes it is a built loose motor, so it's just thirsty.
MegaTRon
08-18-2011 05:03 PM
