Half Shaft Spacers
Half Shaft Spacers
So I have a general question to see if anyone here has Half Shaft Spacers on their S?
This is taken from the T1R Shaft Spacers.(street)
"When lowering a S2000 , its drive shaft angle will definitely need re-adjustments due to the modifications applied, in this case, the lowering of the suspension. This is due to the fact that lowering a S2000 creates unwanted space in between the drive shaft roller and spider (inside of the drive shaft), causing the inboard joint to unevenly wear out."
I know there's a lot of you that are lowered, so I don't know if i should spend the money or pass this up.
Thanks
Thanks
1 Post
Originally Posted by Bryan720,Nov 6 2008, 12:09 AM
you have an ap2 so you dont need them.
I personally have them on my car 10mm spacers. I have the half spacers which takes about 15 minutes to put in compared to the full spacer which is not split in half takes a an hour or so.
What the spacers do is place the axle yolk in a central loaction in side the axle cup. When you lower a car the axle yolk slides out towads the outside and rides in a different grove, which some people feel in a vibration. What the spacer does is puts the axle back in the correct location, like it was from the factory. Depending on how low you are you would need anywhere from a 7mm spacer to a 10mm spacer. I recommend them and have used them for awhile now. Just my .02
