Optimal alignment specs
I got the rears mounted and balanced, flipped the fronts, and had the alignment done yesterday afternoon with me in the car. The shop I'd been using previously obviously leaves a bit to be desired:
Before:
Front
Left..................... Right
Camber: -1.0
Before:
Front
Camber: -1.0
I know I am late weighing in here, I run the "UK" spec and while I see some uneven wear in the rear, (to be expected) I have none in the front.
This is from another post:
S2000 Factory Wheel Alignment (for comparison)
Camber
Front -0 deg 30 min
Rear -1 deg 30 min
Caster
Front 6.0 deg
Total Toe
Front 0 mm
Rear In 6 mm (1/4 inch)
UK TSB Wheel Alignment Recommendations
Honda UK settings are published in degree/minutes and some machines take inputs in decimal degree which is translated by = sign.
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Front 6 deg 45 min = 6.75deg
Total Toe
Front 0 mm
Total Toe 0 deg 40 min (0 deg 20 min per side) = +0.32deg (+0.16deg per side)
When introduced in Britain a number of British magazines complained about the S2000s handling characteristics. In 2001, Honda UK pounded S2000's round MIRA's test track for several days trying alternate settings. In Britain the spec
Camber
Front -0 deg 30 min
Rear -1 deg 30 min
Caster
Front 6.0 deg
Total Toe
Front 0 mm
Camber
Front -1 deg 00 min
Rear -2 deg 00 min
Caster
Total Toe
Front 0 mm
