NEED HELP VAFC
NEED HELP VAFC
So i bought my s2000 used over a year ago. It came with a vafc installed. Earlier today i unplugged it and he s2000 would run very strange. It wouldnt rev up past 3000 rpm and unless gas was given to it, the car would die. went through this for over 30 minutes.
I plugged the vafc back in and the car ran normally.
Any ideas?
Any ideas?
I had a vafc in my car when I purchased it as well. Same thing, when I unplugged it, car ran like shit. It's almost as if the car is still trying to run off the wires that are spliced or hardwired in, but with no VAFC, causing it to run like shit.
Get that thing and all of the wires out of there......I did, and haven't looked back.
its hard wired. and i always have a cel on with my exhaust.
i read in some forums last night that its the map sensor wire. or at least an 00 si with it had a similar problem. i dunno. when i get time im going to remove it.
i had a vafc before but no problems when i removed it. unplug the vafc and disconnect the battery, later reconnect the ecu and the battery. there shouldn't be any residual effects from a vafc. all it does is lean out wide-open-throttle only and change vtec engagement points.
mr_2000
13
03-07-2007 04:59 PM
