Ap2 Mugen Style Lip on AP1
From what I can gather the Mugen style Ap2 Lip only uses bolts on the underside of the bumper. I myself own an Ap1 and none of the ap2s in my town are driving around with a Mugen or Mugen Style lip.
I found a picture in a form and function thread that appears to be what I am trying to do. (If this is not a ap2 mugen style, does anyone know what it is?)
I would be grateful for any feed back or thoughts. Pictures of ap2s with Mugen lips from the underside, or mounting locations of a mugen style lip.
Thank you much.
Thank you much.
![](http://fdkirokubo.cocolog-nifty.com/photos/uncategorized/2008/04/24/dsc_4268.jpg)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-15yr.png)
I think it looks great on AP1, mounting point is central between the scoops, but you can virtually add mounts where you like, especially if its a urethane replica. Have a look at Evasive Motorsports web page and you'll see one off the car, from this you'll be able to tell how easily this will fit to AP1.
http://www.evasivemotorsports.com/me...0_Aerodynamics
![Name: MtTamborine22-04-201111-45-13AM.jpg
Size: 63.3 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132589d1501791993-ap2-mugen-style-lip-ap1-mttamborine22-04-201111-45-13am.jpg)
![Name: 5608550834_04832af969_b.jpg
Size: 132.5 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132590d1501791993-ap2-mugen-style-lip-ap1-5608550834_04832af969_b.jpg)
![Name: P1030671.jpg
Size: 146.4 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132591d1501791993-ap2-mugen-style-lip-ap1-p1030671.jpg)
test fit it on my car a while back.. it does not easily bolt up to the AP1 bumper... and looks better on the AP2 IMO
IMG_1132.jpg?t=1243283017
![Name: IMG_1133.jpg
Size: 28.9 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132596d1501791993-ap2-mugen-style-lip-ap1-img_1133.jpg)
![Name: IMG_1136.jpg
Size: 25.0 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132597d1501791993-ap2-mugen-style-lip-ap1-img_1136.jpg)
I agree it looks really good on the Ap1, I have both the Ap1 front and Ap2 front as well as the rears, and I can never decide which one I like better, however I want the Mugen ap2 lip on the ap1 bumper and I either want the amuse r1 style front lip for the ap2 or the CR front lip. still so many decisions. From what I've understood and read which I have read alot about it, it's not a direct bolt up and you do have to drill holes to get it to fit, however if installed correctly it looks sick, I had the picture at the top as my background for along time because i like the look so much
Even on my ap2 it didn't line perfectly up. I also drilled some holes bc it was just harder to access where they wanted it bolted up. Its all plastic so you shouldn't have a problem. Expect about 2 hours taking your time. Bolt up the 2 sides then prop up the middle, I used my belly, then just drill and bolt up.
i didn't like the hardware either so I had to make a run to Home Depot for replacements.
Member
Spotter
Spotter
![](https://www.s2ki.com/forums/images/s2ki/ranks/com_organizer.png)
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-5yr.png)
Dont mean to bump a semi old thread. Just bought the lip off someone on this forum but it didnt come with the hardware. Anyone got the specs of the bolts I'd need?
![Name: IMG_6947.jpg
Size: 175.9 KB](https://www.s2ki.com/forums/attachments/s2000-body-paint-232/132598d1501791993-ap2-mugen-style-lip-ap1-img_6947.jpg)
I believe it was 8bolts out of the 9 that have been predrilled will fit directly only 1 of the middle front ones will not have anything to line up to and the furthest left and right holes you will have to drill your own hole into the bumper. I took one of those silver clips (not sure what it's called ) that the under panel gets drilled into and shoved those into the sides so I I wouldn't have to use a nut (makes the whole install easier
Reviving an old thread!
Hey mate, i'm looking into buy a new front lip for my ap1 bumper and i saw your example of this and i must say it looks fantastic.
Just wondering if you can post some more pictures from different angles?!?!
I would like to see how it looks before i take the plunge and buy one!
Many thanks,
Many thanks,
i really like this as well! would like to see some more detailed pix also
thanks in advance!
EDIT: went to Google and found some stuff.
this thread
https://www.s2ki.com/s2000/topic/830...nt-lip-on-ap1/
always up for some more detailed pix tho
thanks in advance!
this thread
![biggrin.gif](https://www.s2ki.com/forums/images/smilies/biggrin.gif)
