LS1 V8 SWAP?
LS1 V8 SWAP?
after much debate, ive decided not to go back to turbo and not to autox. ive always wanted a v8 honda. so ls1 it is... project is still under way so be patient...
pics...
pics...
car is getting its wires tucked, engine bay shaved that is why the primer is on. specs on the setup are kind of a secret. it is a special combo that makes everything fit like it belongs. this swap doesnt require cutting but it will be a little front heavy that way...i did opt to cut some bracing and modify the firewall enough to push the engine back an additional 3.5 inches. and due to the stripping/shaving/tucking of the entire front end the car is now lighter than stock and is very close to keeping its original weight distribution. i have deleted the abs and moved the battery to the rear also to help, i think i may have to put it back.lol
Originally Posted by rajun asian,Aug 29 2007, 03:58 PM
That is going to be sick. Screw all of the that will about it not being the car Honda built it to be. Booo haters. Hoooray LS1!
Originally Posted by antonio88x,Aug 29 2007, 06:57 PM
what kind of tranny are you going to use? And which rear end?
