Mark this thread as Sold
FS COMPTECH SUPERCHARGER KIT
Contact: PM, or txt 517-398-5665
Price $4000 obo
Hey guys looking to change things up this winter and do a turbo build so im seeing if there is any interest in my Comptech SC kit. It is still on the car but the car is up for the winter so no more miles will be put on it till spring.
This is a High boost set up off my 00 AP1 that has low miles on it. The SC has around 6k miles on it most highway driving.
It made 405whp and 240wtq @ 15psi tuned by Jeff Evans
What you get
Comptech Novi1000 Supercharger & Comptech Aftercooler( aftercooler is wrapped in DEI reflect a gold. Can remove if buyer does not want it on there. Seemed to help from heat soak in traffic)
Spearco front mount heat exchanger with upgraded Bosch high flow pump(about 50miles on new pump, Stock pump will also be included)
SOS 3" pulley with grooves cut across to stop slipping belts(never had a issue with a belt slipping) gator belt
Turbonetics Godzilla BOV
OEM crank pulley with Comptech pulley attached. NO need to drill and tap your Stock pulley just switch them out and your ready to go!
Has the comptech air box with carbon fiber cover and newer AFI filter. ( will clean and oil for new owner) Also have 2 used comptech filters that the buyer can have if they want. Could use as a back up.
Full install instructions all aftercooler hoses,clamps,couplers,bolts,oil feed,drain,everything to install. I have the stock bosch BOV and both the hard plastic intake elbow and the older style rubber one.
What you will need to run this set up
Fuel pump/injectors i used a walbro 255 and ID725cc injectors.
3 bar map sensor
And some kind of EMS to tune it.
Kit is used and sold as is
ON TO THE PICS
Price $4000 obo
What you get
3 bar map sensor
ON TO THE PICS
ABCVTEC
48
10-27-2008 07:15 PM
D-S2K
47
11-01-2005 10:08 AM
Wesmaster
43
05-10-2003 11:06 AM
