Carbotech enduro compound?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
did anyone try the carbotech enduro pads on an NA s2000?
I read on the TT board the pads are good but don't heat up fast enough for time attack
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
I ran them for the first time (in the front) today. I was running XP10s in the front. I didn't notice a difference except the new pads seem to have a bit better initial bite. I'm interested in seeing how much more wear I'll get with the enduro compound. I've been getting about 6 hours of track time with the XP10s.
I'm having a couple guys try them out right now (Bunta_Garage and Edwin), only have 1 trackday on them so far (XP12 RP2 under Alan). I'll have them post up here what they've found out from their trial runs.
I actually spoke with Emilio regarding this pad. The operating temp range is similar to the XP12, but it has no cold bite, and is less rotor friendly. Additionally, it shouldn't be mixed with the rest of the carbotech line.
It's primarily targeted at drivers who are running sprint/euduros and finish off a XP12/XP16 before the race ends, rather than someone looking for more bite and higher MOT.
Our light weight S2000 brake calipers have a hard time handling the heat generated on the track--assuming you're running at a good clip. Your pads will definitely last longer with good ducting. The same can't be said about the brake disks. Ducting doesn't seem to help with the cracking.
Here's my S2000 brake duct how-to: http://robrobinette.com/S2000BrakeDucts.htm
![](http://robrobinette.com/images/S2000/BrakeDucts/Ducting3.jpg)
Originally Posted by LickyMYwalker' timestamp='1302942137' post='20472685
[quote name='psychoazn' timestamp='1302934089' post='20472518']
[/quote]
hmm ok, well i guess ill be the guinea pig on this one. with summer coming around and the ambient temp reaching at least 90 degrees, it will have a huge effect on things. ill see how it goes
![smile.gif](https://www.s2ki.com/forums/images/smilies/smile.gif)
I too was looking to get another track day from my XP12/10s (I have front ducts...great DIY from Robrob!) and R-comps. After 2 days the tapered leading edge was too thin for me to trust getting another day out of them, though the trailing edge was a lot thicker. As a test, I tried flipping the inner and outer pads so that the thicker tapered edge was at the leading edge. I was expecting less bite and more pedal travel, but was happy at getting very useable and consistent braking feel over 5 25m sessions at Thunderhill. No problems at all getting the third day out of them, though they wouldn't last a fourth.
I like Carbotech, but am going to trial the Cobalt XR2/4s for longevity at Infineon (which is not tough on brakes) this May and then Miller Motorsports Park this July. If the goddess of friction smiles on my, there'll be 1-2 days more left in them afterwards. Otherwise I'm going to try CT's Enduro pads.
Consumables are a lot more expensive then track time!
