Fitted new GT striker plates
Old 09-03-2010, 06:59 AM
p800bry's Avatar
Default Fitted new GT striker plates
Recently my roof catches (drivers side one mainly) started to rattle and squeek. I sprayed them with grease, checked the screws were tight, put plastic fish tank tubing on them and they still rattled so I decide I'd try a set of GT striker plates. The difference is huge! After fitting them I could not even do the catch up with the plastic tubing still in place as they were that tight a fit. Now with the tubing removed I can do the catch up and it has a nice tensioned feel to it when you lock the catch in also with the catch locked if you tap the catch with you finger it makes no noise what so ever unlike before which when tapped would make a rattly noise. To look at, the GT and normal striker plates are quite different with the GT one being smaller and having rubber inserts aswell as having more of an angle on the part that the hook on the catch goes into to create more tension. £60 well spent
Old 09-03-2010, 07:17 AM
Nottm_S2's Avatar
£60 from a dealer? i need to do this
Old 09-03-2010, 08:55 AM
jimmyb1978's Avatar
me too
Old 09-03-2010, 09:02 AM
Johnny 5's Avatar
Do you have a photo of the new plate you can post?
What is the Honda part number?
Old 09-03-2010, 10:48 AM
James_N's Avatar
Indeed! Honda part numbers please
Old 09-03-2010, 12:15 PM
UK Moderator
chrisr111's Avatar
86270-S2A-902
HTH
Chris.
Old 09-03-2010, 12:30 PM
E4RTH WORM JIM's Avatar
Originally Posted by chrisr111,Sep 3 2010, 08:15 PM
86270-S2A-902
HTH
Chris.
Old 09-03-2010, 01:24 PM
robs_silver_s2k's Avatar
I need to do this too. Thanks for the number
Old 09-03-2010, 09:54 PM
p800bry's Avatar
Yup that's the part number. I'll take some pics later
Old 09-04-2010, 05:03 AM
p800bry's Avatar
Quick Reply: Fitted new GT striker plates
