I have received alot of PM's regarding how I hooked up my ECG O2 Simulator. I just made a diagram to make it easier for everyone. Hopefully this will come in handy for alot of people since I got so many questions about installation.
Use at your own Risk!!!
This is the exact wiring I used to install my ECG O2 Simulator on my 2004 S2000. However, I do not assume any responsibility for anyone who uses this diagram. This diagram is based off of my 2004 S, and should work with the 00-03's also, as long as the pin layouts on the ECU's are the exact same.
(I'm not saying it won't work, i'm just covering my a$$, just incase something happens. If something were to happen, then of course I wouldn't be putting up this diagram )
In the diagram, the quote "(TAP)" is plotted next to each wire which requires splicing into.
Note: The ONLY wire you will cut is the red/white wire, which is the Secondary 02 Sensor Wire (C15)
The PCM's wiring hasn't changed between the 00-04. To Hal for taking the time to post a diagram. I'm to lazy to make a full DIY, and this has all the info you need.
S2KEvolution - Thanks for posting this. I was just fixing to install this myself tomorrow and was going to put this exact same info up here since it hadn't been posted before. Saved me the time, thanks. Excelent job w/ the diagram.
[QUOTE]Originally posted by S2KEvolution
that happened to me also. it resulted in me cutting the wrong wire for the secondary 02 sensor. i correctly re-wired it and it was still there. I pull the ECU back up fuse out and left it out for about a minute and put it back in and the CEL never came back on...
so i would...
1)make sure all wire are connected properly
2)pull out the ECU back up fuse
